VR6 Turbo
well its trail and error tbh , but the turbo really spools fast , hernce it may spool out too soon tbh , but had to be worth a try , I've tryed uplading via photobucket u guys might have to join for a quick view , gives u a bit of a idea
Edited by ADAPTORMAN
  • Replies 1k
  • Views 114.1k
Fuck
Haha sounds crap on theer dunt it lol, its sounds awesome in the flesh though if I'm honest
Winner 8-)
sweeeet!
Is this going RR day? Hope it's as fast as the progress has been. Weeeey
Haha, by the sounds of it it will be. No I'm not going i backed out early doors because i didnt think id have it finished, if i get it all built back up and running comfortable then i might still nip up, i dont want to risk a 3 hour journey in a new built though ha
Holy Fuck! haha
Good work bud :D
Edited by daveb142
bit more sorted today , wideband plumed in , more wireing soldered up and started on getting oost pipes to fit to plumb intercooler in next
well were about ready for a tunie
whjxmx.jpg decent idiol afr , timing nice and safe , we will see how the fuel pump holds in boost ,,, hopefully more progress 2moz ,I'm also thinking about doing conversions, spraying, etc for a living ,
What I injectors/fuel pump/pressure reg you using?
:thumbsup: great build,hats off to you both :thumbsup:
get friendly with the local tyre fitter though as you will need mates rates with the amount youll get through with this beast :lol:
I know that the injectors are from an Evo (i couldn't tell you any more qbout them ha), the fuel regs 4.0 bar and the pumps a Walbro 255. jud
Cheers mate, i know i think it'l cost me more in tyres than petrol lol
640cc injectors, only 255 pump we will need to ad 044 for extra boost, 4bar fuel reg, with 21psi map sensor colder plugs
yeah boy! sounds good!
we have to work out my bank loan next ratffmao :lol: , how mutch u guys reckon it would cost for a custom vr6 turbo conversion ,
list includes
remove engine ,timing covers refit new tensionor, refit engine
,remove head refit spacer,rebuild it
, alter exhuast manifold/external wastegate
, add turbocharger, make blanking plate
make a stainless downpipe /bends,
remove sump add oil return, turbo return,
add spark plugs
fit injectors.resistors
fully soldered loom,
, modify intake manifold, throttle body
full blue hose kit
, wire ecu in ,
basefiles,tunie,
wire wideband /gauge in
, instailed intercooler kit,
modify pipes
, modidy bumper
few other bits ,, erm juds work fit ht leads 4 tie wraps, plum boostgauge in ,and ermmmmmmmmmmmm ermmmmmmmmmmmmm makes coffees pmsl ,,,
A fetched sandwiches aswell lol
pmsl and clips , pipe :lol: ill call over do a basic check and hopefully get some tuning sorted
had a few issiuses today , as turbo we fitted was knacked so added another and bingo we have good boost and low down torque , but we need a bigger fuel pump , as its not supplying enoegh fuel , ie fuel map will not richern enoegh , ie not recomended to drive until this is fitted so , we can do a tunie on the engine ....yep sounds nice thow , just keep that right foot off rpm , jud , keep a close eye on afr ,
few pics, enjoy jud , hope your happy with it , (ps i told you you are tyres wouldnt grip pmsl )
I have no idea what your post above says =S lol
but the pic looks awesome....needs black powerlooks and not cheap angel eyes though and also a new washer bottle and coolant tank lol
Out of interest, what AFR figures are you aiming for in various conditions?
Like full throttle on max boost? Cruising along etc?
Great stuff man, How easy was it to hook up the innovate LC-1 to Ms2? As I'm doing the same very soon and would like to know if there were any complications?
The above post basically sais Jud haz too much boostz for z fool pump! It canny tek much mewrrrr! Bosch 044's.. Here you come ha!
Given the fact he's only just got the thing in there I think it would be wise to see what Jud does with the engine bay rather than saying what it needs ;) as long as he doesent put a black stripe down the rocker cover (I'm sure he won't) all will be fine haha.
I have no idea about the afr figures mate ha, Adaptorman will know when he sees the post though.
I definately need a new washer bottle, and the baileys polished header tank I've been looking at. I won't be adding a black stripe down the rocker cover pmsl. I'm struggling for money to undo the black stripe on the bonnet now aswell and its really doing my head in now more than ever. Money thin at the minute, so are the wheels lol.
Needs a good clean now, under bonnet and the body. i can't believe its all gone back together perfect ha, very happy with the work "ADAPTORMAN". Nice tidy job. 5 *****
