mk3 coupe gt arch trouble. help please. !
hey guys and gals. i have a mk3 cl . and have bought gt arch trim for it and i have a few questions if you can help. !!!
first off . fitting the front arch i can see is a doddle. remove the bump strip off the wing , rivet/screw thw arch into wing and i have some like stick sponge that i will put between the arch and wing to stop rattles and water getting in, double sided sticky where the arch goes over the previos bump strip onthe wing. =D laughing.!!
the rear arch from what i can see , you need to remove the part of the bumpstrip that follows the rear arch don towards the sill so the arch can go on, and also the bit of blastic at the rear of the arch thats inbetween the bumper and the arch .=)
rite this is where I'm confused and i need help guys . !!!
the other part to the gt arch kit is the lower side skirts , and i have no clue how to fit them . !!!
there are square holes where obvsley screws go , but there are no such holes on my sills for the screws to go , and i dont fancy just bangin 6 holes in my sill. =D hahahaha. plus the square holes , i assume there is plastic black inserts but i have none , if anyone can help me . please contact me .
thanks guys/gals =D
  • Views 688
I'm assuming you mean the sill trim that runs along the bottom. If you line up the trim where it should be there are actually holes that are there from factory that have been covered up, u should be able to tell where the holes are.
