urgent How do you remove a mk5 6n2 steering wheel airbag
hello, mates bought a gti steering wheel for his 6n2 been trying to change it, but cant seem to take the airbag off, hes tried pushing a flat head screwdriver into the small holes behind but nothing, :x :-X :x
advice would be very much appreciated
  • Views 3.4k
Removing
WARNING
Disconnect battery earth strap before working on electrical system.
– Turn steering wheel -1- until horizontal spokes are vertical. Pull out steering column completely and press down to lowest position.
– Insert a screwdriver, about 5 mm wide and angled to a length of 55 mm, in hole on back of steering wheel hub.
– Turn screwdriver 90°, circlip -2- is pressed off lug in steering wheel hub and airbag unit is released on this side.
– Turn steering wheel back 180° and release second retaining hook on opposite side.
– Grip airbag unit by horizontal spokes and lever out of vertical anchorage.
WARNING
Electrostatic discharges may result in unintentional triggering of airbag. Therefore, the mechanic must electrostatically discharge him/herself before disconnecting the igniter and earth wires. This can be done by briefly touching the body or striker plate of the door.
– Pull connectors off airbag unit
