Removal of door mirror caps
Good evening all
I have a 2005 Polo 9n3, and have picked up some new mirror caps. I was wondering if anyone could tell me if I have to remove the glass on each mirror to fit them, or is there an easier way??
Any advice would be well appreciated
Many Thanks
  • Views 1.2k
Rear view mirror
Removing mirror housing
‒ Fold rear view mirror forwards to ease dismantling/assembly procedure.
‒ Remove mirror glass => page 66-4, item 3. Mirror glass
◆ Clipped in for both versions (adjustable manually and electrically)
◆ Removing - first, press mirror down then up (special tool 80-200).
Protect mirror housing from damage
◆ Installing - insert mirror with guide studs into mounts and press on
◆ Press only on centre of mirror - always use protective gloves
‒ Pull the electrical connections for the mirror heater off the mirror glass.
‒ → Insert a 3 mm Allen key (13 cm long) -1- or similar into the opening of the mirror base, from below, to release the locking lug -2- in the mirror housing.
Note:
The Allen key is guided through the mirror housing and onto the locking lug -2-. Exert light pressure only on the locking lug.
‒ → Disengage locking lugs -arrows- in mirror housing.
‒ Pull mirror housing -1- off mirror carrier -2- upwards.
Edited by nige8021
