puddle of water on passenger side...
hello..
just got into my car and saw a puddle of water on the front passenger side...
the car is parked on my drive facing down and we had a heavy downfall of rain today in my area...
i have noticed water pouring in from the inside of the door pocket...i got door pods now but if you look at the pics you will see what i mean and may see some water drops
have not had a chance to remove door card yet but will do in the morning just wanted to get you guys to give me some info as to what it could be before i mess around and look for myself..
thanks for any help...
  • Views 2.1k
I think it will be the plastic lining on the inside of the door card.
You need to have it completely sealed otherwise you get water running inside the car instead of out of hte bottom of the door. Check the integrity of the plastic lining and replace it if necessary (I got some polythene sheet from Homebase). Use some good quality adhesive to stick it to the door.
i did think it could be that but my drivers door has no plasctic lining and that doesnt leak at all....
must admit when i took the door cards off to fit the pods the previous owner made some cuts and used some crappy masking tape to cover up!
If water is coming in at the bottom of the door card due to blocked drain holes, then surely there would be a gallon of water sloshing about in the bottom of the door.
I had a leak similair to this on a MX5 once, I sat in the passenger seat whilst a mate sprayed the car with a hose, we came to the conclusion that it was the door seal that was damaged somewhere at the top and the water was running around the seal and out at the lowest point, i.e base of doorcard. When my mate pushed hard on the top of the door, the leak stopped. I bought a new seal and it seemed to do the trick. It could also be a combination problem, water arriving in a footwell could be from a blocked hole in the chasis floor, the water runs under the carpet and collects, particulary if you are sloping forward, i'd get underneath and check all the drain holes for leaves etc.
I also had a SAAB 99 years ago which surprised me one morning with a puddled footwell, turned out to be a heater matrix.
i had this problem ended up being the pollen filter was knakerd
give it a try
thanks guys for your help - problem solved!!
it was the membrain after all...i made from a heavy duty plastiv rubble bag :-)
i had this very problem mate check your drain holes by you are polern filter mine were blocked and started to leak threw the polern filter :)
He lists his car as Polo Coupe, so that'll be a mk2 or 3, so no pollen filter their.
Rubble sacks are great for this, in absence of a good quality adhesive, gaffa tape works spot on.
