Car wont lock properly
Someone attempted to break into my 6n again while it was outside my house.... AGAIN. this is the third tim now. The little scrots!!! :x
Anyways, Where they have tried to unlock the driver door with a screwdriver, and failed, They have brocken the lock. My C/L still works but i cant lock the car from the outside on either side :? But i can unlock it...
In order to lock it i have to lock the drivers door from the inside then get out the passenger side and close the door. Or lean through and press the driver lock and close passenger door after. The C/L works fin but i just cant lock it from the outside as i said...
I think the pump on the driver door might be damaged or something, but i dont really know.
Any ideas?
  • Views 913
First of all, move your car before it's gone. Someone specific seems to want it.
Edited by MattLoaf
Nah they dont want it, They just doing it to be a c*nt. They smashed my windows twice and slashed my tires :(
I would move it regardless.
I'm taking a guess here but if its central locking on an older car it will be a neumatic type wich runs on air to lock and unlock ( you will know if it is because the locks will go down in sequence) What if the air line to it was defective? that might cause it and jamming a screwdriver isnt going to help. Check the air line
