Removing black stuff...
Hi guys just removed side strips off my mk3 coupe. It's revealed loads of black stuff. Like glue?
What's the easy way to get this off?
  • Views 933
I used thinners and a plastic scraper but i was getting my car
resprayed so didn't mind leaving a few marks on the paintwork.
It's a real bitch to get off which ever way you try.Even a toffee
wheel was totaly useless and just made a big black sticky mark.
A toffee wheel should work, but try some break cleaner...I've used it before, no worries.
Auto gylm tar remover from halfords and and old card!
I used a rag soaked in petrol and an old Sky viewing card/credit card etc to scrape it off, without leaving any marks done in minutes
Most valeters use TAG ( tar and glue remover ) put alot on a microfiber rag then rub it on, Leave it for a few mins to loosen it up then rub again. Then polish over it after. This also works with any tar sprayed up on the wing and sills.
