big/small spline steering wheel
Had a quick search but couldnt see it. (Possibly me being a bit merry)
I need a momo steering wheel boss for my new wheel, but I dont know if I've got a small spline or bigger one?
Car is a mk2 '89 saloon.
Any help? lol
  • Replies 13
  • Views 5k
take the nut of the steering wheel and see whats behind it! the big spline is about 30mm in diameter- the small size is just bigger than the thread
Shouldn't make to much difference tbh. You can make small spline big and big small.
with Xtreme violence.
Everything is possible when your Xtreme.
Arm't all mk2 small spline?
big spline has a 24mm nut on it my 89 mk2 is big spline
Early mk2 is usually small and late is usually big. However I don't know when the crossover is.
Definately before 1989 though, so it'll be a large spline.
yeah it has a 24mm nut on it, I've taken it off, but i dont know the difference.
I'm guessing I need a large spline boss then?
Thanks for the help guys :)
My '85 no longer has it's original fork-type rack or original wheel, instead it has an '88 wheel and telescopic '88 rack - and this uses a 24mm nut. So you'd think i have swapped to the bigger spline (the day i bought the shell).
However, it previously did have the original rack and a solid plastic MK1 Golf van steering wheel. The Golf steering wheel fitted the late rack because i tried it, once rebuilt, for a laugh.
Conclusion - early wheel compatible with 24mm bolt column, so that's not a reliable indication.
I thought the large splines were merely small splines with collars on, which work as adaptors? If so, you'll be able to see if your spline has a collar on it just by removing the horn push cover and looking at it.
Many VW's of the time had collars. I know how much of a thief they are to remove, since chewing one off the column of a mates VR6.
Yeah it is just a collar mikey so can be removed or fitted to make any column big or small spline
I'm sure someone on here converted a big spline to a little one by using a gear puller to pull the "collar" off?
Either way, If I took a picture of it when It when I get back from work, would anyone be able to tell me for sure if its a big spline or small spline? I'm pretty certain its big, but as I've said, I haven't seen one before at all so wouldnt really know.
Thanks again :)
Rob
Thanks again :)
Rob
its big spline mate
