rear window
i was wondering if anyone knows how to remove the rear window on a 6n
Thanks Richie
  • Views 658
Flush bonded windows
Removing undamaged side window
‒ Remove side trim and B-pillar trim.
=> General body repairs, interior; Repair group 70; Trims; Removing and installing B-pillar trim
=> General body repairs, interior; Repair group 70; Trims; Removing and installing side trim (two-door Polo)
‒ Remove luggage compartment cover mounting and loosen upper C-pillar trim.
=> General body repairs, interior; Repair group 70; Trims; Removing and installing luggage compartment cover mounting
=> General body repairs, interior; Repair group 70; Trims; Removing and installing upper C-pillar trim
‒ Insert plastic wedge between sealing lip and window flange.
‒ Loosen sealing lip from window flange all round and spray in cleaning solution D 009 401 04 (as substitute for lubricant).
‒ → With help of handle -1- guide trimming needle -2- under sealing lip -3- and puncture through adhesive bead (use a side area).
The trimming needle must be guided as close as possible to the window.
‒ Unscrew handle and pass cutting thread through eye of needle.
‒ Pull cutting thread towards inside (use pliers and gloves).
‒ → Guide in cutting thread between lip and window flange with help of tube -1- (If the cutting thread should break, then cutting wire can also be used).
‒ If the gap is too small guide cutting thread on outside and press under the lip with a plastic wedge.
‒ Place cutting thread around the side window.
‒ → Secure outer end of thread on striker pin (apply strip of textile reinforced adhesive tape along route of thread).
‒ Secure inner end of thread on winding device
V.A.G 1654 and cut out window by moving the winding device as necessary.
‒ Press cutting thread against window glass with plastic wedge during cutting process, in order to have clearance at window flange.
thanks alot mate
