Car cleaning equipment
Hi everybody, just wanted to know where people bought their car cleaning stuff from. I usually get most stuff from Helfrauds but i'm sure I would be able to get it cheaper somewhere online.
Also I would like to know what people use. I am looking to buy something to help bring out the best shine of the paintwork. My paint code is LA5M, I believe it Murcato Blue or something like that.
I have read about people clay barring their car and I understand this removes alot of the dirt that isn't removed when washing.
Does clay bar do anything apart from that?
What methods do people use for removing swirl marks and orange peel?
I will be very gratefull for any information people can give. What have you used in the past that works really well and what doesn't work so much...
  • Replies 8
  • Views 948
I always buy from cleanyourcar.co.uk/
Down to the fact I used it once and the service was very very good (ordered a product, wasn't in stock, I was called within 20 mins of my order and was offered a more expensive replacement FOC). have spent hundreds with them, fast delivery, never any issues and you get a decent point system where you can get money back.
elitecarcare.co.uk is also highly rated and if you're on E38 you get discount. Never used them though so can't personally comment.
First you need to get your washing technique right to avoid any further swirls or damage.
I highly rate PH neutral shampoo's. They don't strip any wax off your car so bring out a good shine. Dodo juice - born to be mild is very good, but pricey at £8 for a very small bottle (will last months though). Or Chemical Guys - Glossworkz is a similar product (although not as slippy/easy to use as the Dodo Juice) but you get a decent sized bottle for the same price which should last a good 9 months.
When I used both the above products I was shocked with how shiny my car was afterwards, literally like It's just been waxed.
Don't use a sponge to wash your car. Ever! - Sponges drag dirt across the surface of the paint causing swirls and tiny little scratches. Lambswool Wash mitts don't, the dirt goes deep inside the mitt so it doesn't drag across your paint. Something like this: Mitt
Use a 2 bucket method. One bucket with shampoo. One with water. Dip the clean Mitt in the soapy water, clean a small section of the car, dip the now dirty mitt in the water bucket to rinse, then dip the now cleaned mitt into the shampoo again and repeat. It's shocking how dirty your water bucket will get. After all, cleaning a car with dirty water is counter productive.
You'll then need polishers, clay bars and waxes.. But I could talk about this forever.
Edited by EnthusiastOwned™
Thanks for the tips, been reading up on this all day.
There are so many different polishes and waxes out there, which do you use?
Am I right in thinking that a good detailing method would be:
1) Wash & Dry (2 bucket method) with PH Neutral Shampoo
2) Clay Bar
3) Wash & Dry (repeating step 1)
4) Pre-wax Cleaner
5) Polish
6) Wax/Sealant
If this is a good method which products should I buy, Auto Glym, Meguiar's, DoDo Juice, T-Cut.........
2) Clay Bar
4) Pre-wax Cleaner
5) Polish
6) Wax/Sealant
There are so many products out there, I've only just got into it and it's confusing. get yourself on detailingworld... It's full of good information but so addictive.
As for cleaning I use Chemical Guys Glossworkz or Dodo Juice Born to be Mild shampoo. Both PH neutral. or Chemical Guys Maxi Suds II (loads of soap/foam and easy to use) if I feel like using a normal style shampoo. 2 Bucket method, Sonus sheepskin wash mitt (I also have the Meguiars Lambswool wash mitt which I don't like - ripped after a few months) and the Meguiars water magnet drying towel which isn't too great either; takes a while to actually dry a panel so I'm looking to replace it asap. PolishedBliss offer a fluffy drying towel which has been recommended by my local detailer.
Polish I use a combination of Auto Glym SRP (which doesn't really cut, it's more of a filler polish), Farecla G3 and Menzerna stuff with my Rotary.
Wax I use Collinite No. 476S. A very tough wax which leaves great results. Cheap too. I have used Dodo juice Blue velvet before and it's awesome stuff.
I do it this way:
1) Wash & Dry (2 bucket method) with PH Neutral Shampoo - Dry with a drying towel to avoid water marks
2) Clay Bar
Repeat step 1
3) Polish
3.1/3.2) Clean windows/re-black plastic
4) Pre-wax Cleaner
5) Wax/Sealant
do you clay bar everytime you wash?
Do you have a superfine clay?
I was going to get a coarse bar for once/twice a year and then a fine bar for rubbing over every other wash or something like that...
Not every time.. Once a year, twice max I would say, some people say more. You should only really wax your car twice a year in my opinion, once for summer, once for winter. A decent wax will last that long. You only really need to clay when you wax because you don't want to trap the contaminants under the wax. If you prep then wax your car properly then keep on top of your car cleaning any contaminants shouldn't stick.
Claying a car is for removing contaminants on top of your paint work. So run your hand across your paint, if it feels bitty then clay will fix it.. If you see contaminants but you can't feel it with your finger then that's usually under the paint so it requires a polish. Polish usually is a slight abrasive so it removes some of the paint, where as clay just removes anything which is stuck on top of it.
I always use the Meguiars Quik Clay kit, it comes with just enough lubricant and clay for a car, plus at £15 a go it's pretty cheap. I'm unsure if it's fine or coarse, but it does the trick. I'm unsure on other makes of clay as this seems to work fine for me. Detailing world should point you in the right direction.
Edit: Bilt Hamber clay is meant to be very very good and everyone raves about it.. It works with water as a lubricant which will make like easier.
So do you polish every time you wash or do you not need to if you have applied the wax? As in the steps said before you polish before the wax so does that mean you shouldn't or don't need to polish after washing a waxed car??
Wax is a protection for your paint, not only does it make the paint shiny, it stops grime sticking to it and also acts as a good guard for stone chips and the like. It's effectively another layer on top of your paint.
Polishing is a light abrasive. So it takes away layer of paint (including removing anything on top of the paint i.e. the wax). So if you polish you have to wax again.
You shouldn't really polish a car without claying it first either; as polish only removes defects within or under the paint, if you don't clay before a polish anything stuck on top of the paint may become loose and act as an abrasive. I.e a bit of hard tar breaks loose when polishing and gets dragged across your paint = swirls. Where as claying picks up that bit of hard tar and removes it from the surface into the clay and away from the surface.
Also, as polish is a light abrasive and removes some paint, if you polish every time you'll eventually have no paint left. I've seen quite a few old VW's (red ones only for some reason) where some panels have been polished through to the primer.
You only need to polish if there are swirls or scratches.
