boot lock
okay, so i came to open my MK2 boot last night and the lock isn't working...
when it's unlocked, it just goes in like it's locked, and it clicks a bit?
also clicks while i'm driving which is a little disconcerting..
anybody had the same problem and know if it just something i can easily fix? or do i have to get a new lock? if so where can i get one?
tah
Ed
  • Views 897
open the boot from the inside and then take the plastic boot cover off.. you should then see the locking mech and you can diagnose what it is actually doing.. it could be the little leaver is broken.
alright, tah, will i be able to close it again if i open it and the lever is broken?
yeah no problem... well yes if its only the button broken..
might be a bit of a pain but if you take off the black plastic panel with the boot close you should be able to see the same thing.
