re-fitting fuel tank
Seriously need help. Just tried to refit the tank on my mk2. Managed to scratch all the paint off, drop the tank on my face, get shit in my eye and punch a f*cking great dent in the door.
The haynes book of lies says get a friend to help but whenever I need help all my friends disappear, how can I get this tank in on my own?
I'm gunna hurt this car.....
  • Views 724
Sorry to hear your getting all raged up with the car, i know the feeling.
What you actually having dificulty with? Getting the tank into position? Or actually fitting it?
Bit of both, I can't hold both sides up and get the filler neck through the gap at the same time. I also need to hold the handbrake cable out the way and connect the top hose as it slides into place.
i did it myself on my mk2, used two jacks with a bit of wood on each to support the tank in place, you need to get the car quite high up in the air in order to get the right angle to get the filler neck past the sill/qtr panel up into the filler area.
i got the pipes into place by shoving my arm thru the filler hole while the tank wasnt fully fitted in place.
didnt have problems with the handbrake getting in the way, but i had a early mk2 (85) so my tank was smaller.
if your getting pissed off, id definatly ask a friend to help, if they all disappear then they arent really your mates! and you may be better off trying to find a friendly polo-er from round your way off here!
What a difference a coffee makes.
Thanks for the help guys, finally got it done. Someone has previously repaired the sill and it wasn't the same shape as standard so the filler wouldn't go in properly. I bent it back, rammed the tank in and hammered it roughly back into shape.
After all that I realised I'd forgotten to connect the big hose at the top of the filler so I worked that on with lots of patience and a very big screwdriver.
I disconnected the handbrake cable completely to get it out my way, then reinstalled it afterwards but, now that I think about it, I forgot to clip it back up.
