that awkward moment........
when your wheel bolts decide they dont wanna work anymore :(
  • Replies 25
  • Views 2.2k
Mine did the same, but a mate didnt tighten them up as much as i thought he would. Did it bent your arch?
Eeeeppp! What happened?! Gona need a new wing?
mini fitment wheels with std bolts instead of wobble bolts?
What i was thinking.
you got it in one but they do fit as the bore is diifferent and with a bit of lift they work its just a had the cut a bit of my bolts of for my last weheels and clearly they wernt long enought :p
and yer bent arch and subframe engraved the floor hard x
common sense dictates that running pikey bolts is gonna end in tears lol.
coilovers - £200
wheels - £150
failing hard - priceless
:lol:
Cut bits out of your bolts? What the actual fuck? :lol:
Some of the pikey, home brew, bull shit that goes on here is damn scary.
Let me get this right.... instead of buying some wobble bolts to make the wheels fit properly and safely you used some bolts from some other wheels that you 'cut bits out of'? You now have the cost of a new wing, subframe and whatever else needed so your car is back together. Then you will still have to buy some wobble bolts if you want those wheels to fit right.
Wow.
looks like a 10mm universal spacer on the floor....
I'm assuming he's used original bolts (that he's cut bits out of for some bizarre reason), lashed the 10mm spacers on that are required to clear the 6n brakes when using mini wheels, meaning the already shortened bolts would be yet another 10mm short.
it's scarey that people are willing to drive around in death traps like this. Get some fucking common sense.
The awkward moment when you bodge a job and it bites you in the arse.
Lucky it didnt come flying off and hit someone.
Your a fool for not using the correct wheel bolts. Hopefully a big lesson learnt here.
5ml spacers actually x
and i had pepperpots with adaptors and the bolts were to long so had to be cut :p
new subframe? yer rite it hits the floor like most of the time i drive anyway so fuck that x
Sorry, I read it as you'd bent your subframe.
So you used 5mm spacers with bolts cut too short on wheels with an incorrect PCD and centrebore for their intended use?
epic camber FTW!
jakeymet, you do realise you could have caused serious injury to yourself and more importantly others, had that happened at high speed. I would explain the engineering science behind it, but it would probably overload your brain cell. But in basic terms all you need to know is that if you run mini wheels on your vw you need wobble bolts and spigot rings to be safe.
epic camber FTW!
got spiggots so center was rite and no u dont need wobble bolts
you put one bolt in the u can turn the wheel eaither to give you that 2ml on each hole
relating to this
http://www.clubpolo.co.uk/forum/index.php?showtopic=256119
If this had caused an accident, this is a situation where the insurance company would be perfectly in the right to void the insurance and the driver would be liable for any damage or injury to the other person!
So if you are going to mod your car do it properly!!!
relating to this
yes because everyone does dont they!
your all crying cus i havnt used wobble bolts x
epic camber FTW!
yes the bolts will go in but they won't seat correctly...
did all the bolts snap or just fall out?
relating to this
If they don't then they are idiots...
and we are pissed off because you could have hurt someone you idiot!!
relating to this
Your the one who posted a picture of your car in a bit of a state after saying you didnt do it properly.
Nobody is crying, more like cringing.
relating to this
the bolts fell out cus there had been but like 3ml of the end and only about 3 threads were in the actually hub
and i was in a 30 doing 20 with noone around and the wheel fell into the arch so it couldnt of hurt anyone
relating to this
:lol:
So when you set off out in your dangerous car you knew that no one else would be using the roads? You can also predict the physics that will determine where exactly a wheel that has sheered off at 20mph will go, whilst taking into account all the variables of this scenario? If so you can not only predict the future but you are also a physics genius. You're lucky is the long and short of it. Lucky you didn't hurt yourself or others using the public roads.
Its funny that you seem to think a worthwhile defence to all this and not using wobble bolts is that you used ones that you knew were too short and therefore dangerous?
Edited by demolover
relating to this
:lol:
Its funny that you seem to think a worthwhile defence all this and not using wobble bolts is that you used ones that you knew were too short and therefore dangerous?
yes i never said it wasnt dangourouse you pleb just everyones crying at a mistake x
