mk3 steering wheels + adapters
bought a mountney off ebay with 100mm between the small bolt holes
bought a boss from high peak low dubs cheap with 80mm between the holes and about 29mm spline hole, was told it was off a 92 is this right for my 91 polo? (not got round to trying it yet)
and together
I'M DOING IT WRONG!
what should i do? which bit is in the wrong (not usual size etc...)?
  • Replies 13
  • Views 2.5k
Is it a mountney?
My Momo Nova wheel is 70mm between centre's, which by the looks of it would fit on your boss.
I could knock you up an adapter and you could come and pick it up? Or just buy the correct boss from eBay, there only about £20
Is it a mountney?
deffo is a mountney, its circa 1987 and never been used! :shock:
this wheel is worrying me as the centre seem wider compared to others i've seen and i'm worried it wrong :S but i'm a noob so i don't know what i'm talking about
errrr could do i suppose but you'd need measurements and that obviously, how much you reckon? and won't it affect me fitting a centre/horn?
It might be hard as id have to have the horn your using to get measurements....
Your best bet is to sell that boss and then buy another off ebay that can take a 100mm PCD
damn! more complications! everything that i've done to this car has been trouble so far :x i've not bought a horn push yet either as as per i thought it would end up being wrong, these are the only ones i've found on the bay; number 1 number 2
aaaah twas me indeed, i forgot about them but apparently you have to ring them up :S
Yeah
Probs so they dont get people ordering the wrong ones online then having millions of returns to sort out ;)
is a 91 a small are large spline then? if its large i cn get a boss for a late mk2 golf and it will fit
yes its a large spline, unless you take the adaptor off, then it becomes a small spline....
Edited by Mk1_Golf_Chriz
  • 5 weeks later...
right i've decided I'm removing the spline adapter and getting a small spline boss now i've been paid but which should i get from this site the polo up to 82 one or golf/derby up to 82 one?
come on peeps i want to order one!
they should both be the same mate as both the early polos and early golfs had the small spline but i would go with the polo one at least you know its for your polo then.
what i've been waiting for! CHEERS!!!
