Mk3 Polo ARB
I have a Mk3 Polo GT, and whilst i was changing the arb brackets to some new G Laderseite blocks, i noticed on the passenger side the rear bolt was loose. After the bolt came out and trying 2 apply a new one i noticed the thread has all gone, and it doesnt hold the bolt in what so ever. what are my options here? Its in an awkward place also, as its covered up :(
Cheers, Chriz
  • Replies 10
  • Views 1.5k
Cheers, Chriz
You got a threading kit. can you re-thread it, if thats not an option take it to an old cheap garage and ask them to re-thread it.
what tap and die?
yeah mate, they use to sell them cheap on the tool section at lidl/aldi if thats any use.
cheers chap, but already tried a tap and die, and it still didn't want to grip :(
can u get a nut on the other side of it, cant really remember how they look, is it possible to have a nut and bolt threaded through?
youlll have to drill it out and put the next tap size up in it. or you drill it to a certain size and put a helicoil in there. dont know what else to suggest really mate. apart from a nut and bolt if you can.
if my memory serves me correctly you can remove the plastic cover from the side of the bit it bolts to and put a nut on the end.
Just stumbled across this image, and by the looks of it, the whole piece can be removed? number 35. Can anyone confirm this? if this is the case surely i can just simply undo the bolts and remove the piece, weld in a new nut or just replace the piece?
Edited by Mk1_Golf_Chriz
I'm sure that removable piece is just on the drivers side, as on the passenger side the mounting pount for the arb is the underneath of the gearbox mounting point on the chassis rail.
thats how it is in a mk2 so i presume being the same chassis its the same on the mk3.
Yeah that picture is back to front.
This isn't an uncommon problem, personally i'd weld a new threaded fixture to the inside. Hold it in place with a bolt, get a weld in the hole in the side of the box section. Or just get a spanner in there and use a loose nut, as someone above suggested.
I don't think there's enough meat on the damaged fixture to go to the next size.
