bonnet extension pieces
Was looking for a new bumper and came across some,only saw pictures of them fitted but am I right in thinking that they are just metal pieces that weld onto the origianl bonnet$
  • Replies 11
Anyone
If there smoothed into the bonnet then most likely. Or you can just buy the abs plastic ones to go on your lights.
How do the plastic ones work?
Would the plastic ones need fixing to the bonnet, considering buying one
Edited by deanwt
i thinkk! the plastic ones bolt on to the front end, where the lights are bolted on.
I was planning on doing this but it does look rather naff, get a weld on one, looks alot better
So the plastic one would be a seperate piece to the bonnet? Think a properly welded one would look better if that's the case tbh.
Do the metal ones just literally get welded onto the bottom of the bonnet?
Plastic ones are usually called light eyebrows and were very popular among the mid 90s and were a cheaper and removable option compared to the bodywork costs etc of the permanent welded version. However it looks a lot more proffesional when done righr. This version originated back in the 50s when 'rodders' had frenched taillights etc. Metalwork was the modifying back then... Not fibreglass kits blurgh!
Thinking of this, any opinions
Edited by deanwt
How difficult are these to actually get on, my mate said he can sort it but trying to find out what he has to do so he knows
I assume what your mate would need to do would be:
- get the piece the correct shape/size needed
- sand the paint/filler/whatever off the front of the bonnet to allow him to weld the new piece onto it
- grind down the welds so they are flat
- paint it and hope it looks nice :)
I don't know for sure as I've never done one or seen one done, this is just my guess.
Cheers, I assumed as I was buying it as sort of a kit containing 5 pieces that they'd all be sized and shaped up correctly
