6n bump strips
Was just wondering do the bump strips on a 6n have paint underneath them when you take them off or are they clipped on so you have to get them fillled and painted etc, any help would be much apprectiated :D
  • Views 888
they are just glued on with a horrid sticky crap.
they have paint underneath but this sometines ius faded when the strips are removed due to no sun/polish etc.
sometime syou get away with it and its perfect
there is a guide on how to remove these properly on here somewhere
like said above they are just glued on.
I poured hot water (not boiling) over the strips and slowly pulled at the bump strips. They will eventually start to come away from the body.
Then i used the toffee wheel to get the sticky stuff off which works really well and are like £5 off ebay, but if you dont have one then just use sticker remover or something similar.
Then i t-cut the marks off and polish.
Then you should be left with a nice smooth door :biggrin:
Edited by rozza92
Okay thanks guys for your help :D
