Mk3 Polo OEM Sump Gaurd
Hi all, looking for some info on Mk3 sump guards.
I *think* that if I can prove it was a factory option and that it mounts to where I think it should (TCA mountings + ARB mountings) that I can get away with running a PPP stage 2 subframe in my hill climb class. The reason being that the PPP subframe may be similar in design, just with fewer members and different materials. That way I am running a modified replacement sump guard and not custom chassis reinforcement ;)
I've used the search function on the forum and only found a single image take from outside the car at head height so it's VERY difficult to see any detail. I also can't find any mention in ETKA of the part, but that just may be an over sight on my part.
Ideally I would like:
1) Some better pics of the sump guard off the car
2) Some better pics of the sump guard fitted to the car
3) Any screen shots or scans that show it as a part in a VW system or brochure.
Any help greatly appreciated. If genesisGT is on here I hope he will come to the rescue with a barrage of info!
If it helps spur anyone one of my main competitors is a 1400cc 8v Nova Sport that's a) mint condition b) really quite fast! Would be nice to represent the Polo's well! Ever little bit will help.
  • Replies 8
  • Views 1.7k
yeah but there's a standard part for a mk3 polo. It is in ETKA somewhere I remember people posting pictures of it in there but I've no idea where unfortunately. I think there is an extra section in there for accessories and stuff
Went through ETKA on VAG CAT site again to no avail. I'm sure someone will know just the page to bring up.
its in the engine section TAV after the block and sump.
it fits to the TCA inner mounts with wee metal plates and bolts on to the passengers chassis leg & drivers ARB mount bracket. it acts as a brace bar aswell i felt it tightend the front up a bit stopped chassis leg flex a bit too.
I dont think you could run a PPP frame and it as the same time due to the front mounting positions as they are higher than the factory ARB holes. i have considered it but the guard sits quite low, i grazed it a few times round Glasgow city centre and I'm only down 40mm.
i think you can squeeze a PPP 4 branch above it as i mocked it up on mine and seemed to fit by a baw hair or two. only way a PPP frame would fit is if you put in spacer blocks and trimmed the front edge a bit with a grinder. but it would be so low then! Even G lader site blocks would get in the way slightly.
its was £120 all in about 5 years ago but belive one of the rear brackets is low stock if not obsolite now but you could make one using the other as a rough guide as they are left and right handed out of a thick bit of sheet plate. German ebay has them ocassionally i got 1 of there but they are rare there too only russia and norway or sweeden (forget which) got them as standard.
the guard itself is open to allow airflow and has 4 bars that are about 3" wide. it wont stop everything but stops most things. mine are up the loft just now as my cars in bits but will have a hunt should have pics somewhere when i first fitted it.
VW do a plastic one to listed for the diesil but its shit in terms of impact. good for water and mud though but its mega expencive for that it is and think half the fitting bits are obsolite too.
Edited by genesisGT
Excellent, great reply as I hoped.
I'm not looking to run both at same time, just the PPP setup. But if quizzed I can point at it just being a variation on an OEM part.
Pics would be a great help, I might have some explaining to do when I rock up with lots of tubular steel under my car, one wing mirror and a missing stereo system etc etc.
Just where you said it'd be under the sump section, can't believe I looked over that!
This makes me confident I can fit the frame and not break (even if bend) the rules :-o
Ah, I always wanted one of these. Don't really know why, just love oem extras! Guess it won't fit with a stage 3 if a stage 2 isn't compatible though
