Help! Thermostat bridge housing replacement
Right,
So I have had the usual problem with it overheating due to the pin on the thermostat bridge housing snapping
So i have come to replace it. Not too hard whatsoever however WTF is with that pipe behind the block attached to it? I cant seem to seal it behind the block and it keeps pissing water all over the place when i try to fill it up. Does it come with an O ring?
I cannot seal it whatsoever and the pipe that connects to the bridge housing also leaks. I have spent hours on this now and am none the wiser
the Haynes manual is wank and this is making me want to bin the car! Not happy...... please help!
  • Views 880
Popular Days
13 032121065D water pipe / F >> 6N-V-300 000
(13) 032121065D water pipe / F 6N-W-000 001>>
14 032121665A round seal 37,5X4 /
15 032121666 round seal 36,5X3,5 /
16 032121142A retaining spring
item 13 is the pipe that attaches to the water pump housing
