paint structure
how were the 6n2 polos painted. is it primer, paint then laquer? or did the use clearcoat on top.
  • Views 1.2k
iirc it was galvanized > primed > paint (water based?) > then the clear coat.
clearcoat is lacquer
The 6n2 was galvanised, primed, painted most likely in a solvent at that time then lacquered
i know it was a retarded question but I've bene reading and some people say clearcoat and lacquer is the same some people say differently. how thick will the primer, paint then clearcoat be? looking for quite an accurate answer if anyone knows?
clear coat is just a differant term for laquer..its the same stuff
you can get paint measuring gauges if your that keen
id imagine at least one stage at the factory was dipped
