Painting or suitable adhesives for an engine cover
Ok so i changed all my leads again after one decided to break after 2k :@ took my engine trim cover off for access while it was off i cleaned it up and debaged it, now I'm lookin at trim to tart up in my engine bay but obviously it gets to scorchin tempratures under there, I'm debating weather to self flock (not the proper electrode way lol) or to paint it
However i dont want tge material to fall off or the paint to buble
What suitable adhesive can i use sonething that nots gonna show through material or what paint as the vht paint only comes in crap colours that just wont go with the motor its purple and black atm
  • Views 953
High temp paint should work for you. The higher the temp it can take the better, I think Hammerite can take high temps, so take a look, not sure what colors it comes in though.
Looked into this, what you need is a base coat of plastic primer as its flexible in tempratures, then a few coats pf standard primer, then paint the colour you like and a laquer to stop contamination
Done the job for me its still good ill let you know if it lasts tho ;)
The plastic cover doesnt actually get too hot, so any normal paint should be ok. As you've found
Might get a picy up on the thread, just a quickie prankstar as i know your in to your polishing and detailin, with an engine top end, when painting is it necessary to use primer? And laquer? Hi temp of course...
