Polishing engine components
Gonna attempt to do the rocker cover on my mk4 what things do I need n where do I start thanks
Wet & Dry ranging from around 300-2500 grit.
WD40 I find helps.
Autosol.
Rub down with the lower numbers, and slowly work your way up, finishing with 2500 grit..then polish up with autosol, takes time and patience
Mguiars do a good metal polish. Use after autosol to get a major shine. Think it's called extreme or some shit, green tub with a purple top
Musnt forget the all important degreaser and cleaner ;) gunk do a good engine degreasent, my old arosa had a gleaming bay lol
Or if u want to keep cost down use a white spirit on a old cloth or sumin
