MK3 arch question
Something I've been wondering for some time....
I see a few mk3's with arches and no door strips and the stem which is attached to the front arches removed, is this just a case of cutting it off and somehow plastic welding the gap? or are they off and earlier model or something?
cheers
  • Views 799
Can be either
A lot of people do just plastic weld the gap and paint
But you can get arches off of a MK2 to fit.
They didnt have the bits for the bumpstrips and are a straight swap pretty much. Fronts are different though, you have to cut the end off. You will realise why just thinking about the difference in bumpers ;)
Edited by B-shaw
Ok cheers mate, so even though the arches will need to be cut to size, its easier to just throw some mk2 arches on
Yess thankyou!
