mk2 bready fuel consumption
hi, i used to drive my polo (MK2 polo C 1l) about 70/80 miles a week, which cost me about £20/half a tank a week, but today i've done a test run for my drive to uni when i start..
it's about 14 miles there, so we'll call it 30 miles there and back,
I used about a quarter of a tank!
There was quite a lot of traffic on my way back, it took about an hour, but i still wouldn't expect it to use so much petrol?
Is that about right for my polo or should i check it out? Also, any ways to reduce fuel consumption?
Tah,
Ed
Edited by edwardscott_30
  • Replies 30
  • Views 3k
Thats using more than my coupe, n mine is bike carbed!
hmph...
I was driving quite economically too, i thought.
I think it could be my roof rack...?
No, unless your roof rack is very very heavy it wouldn't affect fuel consumption, espescially through town.
Sounds fucked. Sitting in traffic does kill fuel economy though...
My corrado does more than that to £20, and I rarely see over 30mpg unless on the motorway!
Need a new carb...
The weight is practically irrelevant. It's the increased air resistance that reduces economy. However, you are right in saying it won't have a noticeable affect around town.
Regarding op, check your carb is ok. Which carb does it have?
Yeah, i know the weight is pretty insignificant, but every time the wind blows i can feel it pulling my roof rack =P so yeah it's the air resistance thing.
I don't think i have a carb?
I think it's just fuel injection..
i've taken the roof rack off anyway, just to see if it makes a difference, worth a try eh.
what year is it?
i have a 1987 bready mine ant bad on fuel and they all have carbs unless urs is differant never seen and old bready not carbed it must have a carb!
My 1.3 4+E coupe s used to do a pretty steady 40-45mpg, always found 1 litres to be a bit worse because they work harder and are normally 4 speed.
how on earth did you manage that? mine would do 30-35 max on a good day when standard
Is it a mk2 (small bumper) and not a mk3? If it's the former, it will have a carb.
By all means have the roof rack off. But i gaurantee it will not sort the problem. First thing, check your carb is working fine. Is the auto choke working ok?
Did you have a 4+e Eric? It has a very long fifth. Then again, I'd get 40-45 with my standard 1.3 if I drove carefully.
Off topic, Eric, did you get that windscreen sorted?
i get average about 42mpg with my 1.3 mk2. got a four branch on, running standard pierburg at the mo. although I did convert it to 5 speed.
edit - best I've had out of a whole tank is 46.5 mpg
I use a wacky android app so keep track of my fuel.
Edited by runforrestrun
yeah 4+e bro, gonna be using it in the afh too.
nah i still have the wedge crack in it! haven't found a screen near enough to me! haha
~48mpg
the year is 1990, and i'm pretty sure it doesn't have a carb...
i'll go take a picture (you might have guessed i'm not great at the whole engine thing, terrible memory)
i'm not sure about my auto choke, although it does seem to idle quite high sometimes? is that easy to check/tweak?
here's some pics, hope they're good enough, got wet socks for those. =P
i don't see a carb anywhere, and the thing sortof near the middle in the second picture looks like fuel injection?
okay sorry guys, me and my brother just went and had a look and he found my carb.. =P
I have no idea about mpg but in my 1.0 mk2 bready I do about fifty miles on a tenner.. and I can only ever afford to put a tenner in so when my mileage hits fifty I put more fuel in! Constantly living in fear of running out..
yeah, i've been doing about double that the whole time i've had it!
only just noticed it as a problem cos i've not had any other cars and it's what i was normal... thought 20 quid for 70 miles was normal, never thought to work out mpg!
which i just worked out.. about 23 mpg.. not good.
It might be worth having the carb checked out by a professional. The mixture may be set too rich too. Can you smell unburnt fuel at the exhaust?
no, i don't think so..
me and my brother are gonna have a look at the auto choke today.. i HOPE it's that, but i doubt it will be.. if not, i guess i'll just have to get the carb checked out..
unless you can think of any other reason for using too much fuel?
i'll keep you all posted. (cheers for your help)
