mk2 bready fuel consumption
me and my dad just wen out too see if it smells of petrol, and dad said that it "smells very fumey" but i'd only just started it, so i guess that's inevitable, and he says that the black lining on my tail pipe suggests that the mix is very rich, says a healthy exhaust is grey? not sure how true that is, looking at theother exhausts on the drive, they mainly black..
another note, when i first start my car it often turns off again, or stalls when i pull of, which i imagine suggests the auto choke is a bit iffy?
  • Replies 30
  • Views 3k
If you are over fuelling check the plugs and see if they black. .
I had one of these and the fuel pump was knacked. But you could really smell fuel the diaphragm had popped and it splits fuel out a little hole on the pump.
The pump is on the back of the block in your second picture and works of the crank pretty cheap too about £20
Check all the connection are clean to the autochoke and check earths. my on the Golf wasn’t connected and the person before turned the idle all the way up so when I reconnected it was all over the shop.
I can recommend Midland Tuning Specialists, in Birmingham where very good sorted out my 1.8 driver when it was over fuelling. Cost about £65
alright cool, thanks man.
okay, been out and checked over everything.
the auto choke doesn't seem to work properly, and also the carb has petrol on the outside of it, so we reckon it probably needs new gaskets or just replacing?
the carb i've got is weber (we think 32 TLA), which apparently isn't standard?
the spark plugs seem okay,
we reckon the problem is that the carb is leaking from one of the gaskets, and air maybe is coming in which is messing up the mixture? and then on top of that, the auto choke seems a bit weird so it's idling a bit high.
also, we noticed in the carb, there are a couple of bolts which my brother thinks are body bolts, and they aren't screwed in completely, so we think that could be loose, therefore letting air out there too?
ANOTHER thing i've noticed, there is a bit of water spitting out of the exhaust, does that mean something bad?
tah
Edited by edwardscott_30
if you need a new mech fuel pump I have one, pm me
Edited by runforrestrun
My 1.3 4+E coupe s used to do a pretty steady 40-45mpg, always found 1 litres to be a bit worse because they work harder and are normally 4 speed.
how on earth did you manage that? mine would do 30-35 max on a good day when standard
Hydraulic lifter engine a reasonably healthy pooberg and setting the carb and ignition up totally by ear.
