Putting a GTI Splitter onto an SE.
I want to get a GTI splitter onto my Polo 6N2 but was just wondering how hard or easy it is? I looked underneath and there's just a few clips.. is it just un-clip the old splitter and clip the new splitter in from underneath?
Jamie
  • Replies 8
  • Views 1.2k
Yeah, it's that easy. Mine needed a little heating to get the last clip to pop through, but it's not hard man. :)
Cool, good to know! Cheers for that mate!
Theres also one screw/torx on either end in the wheel arch.
Pete.
Pete.
Its as easy as taking your exsisting 1 off just basicly clips on !!!
I used a wide (but blunt) flat screwdriver to unclip the standard splitter, clean up the area with some IPA and clipped the GTi splitter on. I had to pull on the splitter slightly to get the last couple of clips in.
Cheers for the help guys, should be fitting it tomorrow! :D
Yeah it is pretty simple. When I fitted mine I had the bumper off the car and tried a couple of times and couldn't get the thing on.
Anyways I stuck the splitter in the bath (don't tell the missus!!!) with boiling water and the thing just went on easy as!
Heat makes it much easier and you effectively dont have to cold stretch it (which doesn't always go back) therefore it gives a tighter and better fit!!
Ah sweet man il keep that in mind!
Tried removing it the other day but because my drive is incline I didn't have enough room to get under the front bumper so getting my mate to jack my car up on level ground sometime soonish!
