Mk 2 Polo Caddy Purchased !
To cut a long story short I got rid of my Mk 1 Golf GTi cabrio with the intention of purchasing another Polo as I like my breadvan so much and fancied taking on another project but I really wanted something a bit different . So I went out and got this .......
It was originally a 1985 1.3 GL Saloon . It is a 4-spd with a coupe S interior including clocks , also i have the black headlining to be fitted , its covered 65k . Its lowered 40mm and currently running 14" Mk III golf wheels with stretched rubber . I even has a functioning tail gate . Needs a clean and a few little touches but I'm well happy with it ! Opinions welcome :-D
  • Replies 20
  • Views 1.7k
Saw this in golf+ a while back. Best paddy I've seen yet. 'loon is definitely the best basis for this conversion
Single light grille and big engine would see it perfect!
I really like that. I like the way it has been made out of a saloon but used the hatch rear lights and tailgate. Just need to be lower on the front and higher on the back and it'll be spot on.
oooo seen this before somewhere, looks awesome. proper build. people were saying about it having to pass some sort of test though or something?
Has this been through an SVA? I was under the impression that there was no category for converting cars to pickups and therefore they couldn't be registered on the road legally? If so, VOSA will have it off you if they see it!
Looks tidy though :D Hopefully it's all above board because it looks sweet.
Edited by tezmc
thats what i was on about ^^^
that is a fantastic conversion, I've seen a few and this one is the only one i have seen that looks good. But as above i can not see this ever being legal. Curious to know exactly tho!
LEGEND!
looks bloody awsome dude,is it all legal road wise then?
so much potential
Did a little research into SVA tests and found this information.
The Single Vehicle Approval (SVA) scheme provides pre-registration inspection of vehicles less than 10 years old that have not been ‘type-approved’ to UK or European Union (EU) standard
Looks like if it needs one you would have to contact whomever built it.
3. Amateur-built vehicles (A)
To qualify as amateur-built, a vehicle must be constructed or assembled for your own
personal use, and:
• the construction/assembly or a substantial part of it must have been carried out by
you or others acting on your behalf; and
• during its construction/assembly, neither you nor any of the others involved carried
on a business in which motor vehicles are normally constructed or assembled.
When you apply for an SVA inspection under this class, you may need to provide evidence to confirm compliance. This could include receipts for parts used in the work. An amateur-built vehicle will only need SVA if the DVA Licensing decides it has a new identity. At present, DVA LICENSING NI gives these vehicles a vehicle registration mark from the current series or a 'Q' prefix. Those allowed to keep the donor vehicle’s registration mark will not require SVA. For more information, contact DVA LICENSING NI Enquiry Section or any Local Vehicle licensing Office.
http://www.dvtani.gov.uk/uploads/vehiclete.../svabooklet.pdf
Edited by MattLoaf
Looks awesome!
One of the best I've seen. Be the best if the stance and wheels are sorted ;)
thanks for the comments fella's , I'm well happy with it . My concern was the legality of It but everything Is present and correct paperwork wise and more importantly legal . I contacted the dvla as the log book described it as a hatch , so I've arranged for a VIC check so they can more accurately describe the vehicle and issue a new book . Just want everything 100% should i ever come to sell it :-D
hmmm, i still can not see how it will be legal. Did you tell them the original roof and rear supports have been cut off?
As said above it will need a SVA test and going off the guides will fail, i dont think speaking the dvla about getting the description right is what we are saying.
When you say everything is correct and present paper wise, what exactly do you have?
Just checking and curious more than anything!
And this is where you're going to fall down :( When you go for the VIC check, it will be referred for an SVA due to the type of body change. There is no classification for the SVA to convert a car to pickup, so they can't do the inspection. Therefore, it can't be registered on the road as a pickup.
Edited by tezmc
As has been said, a really cool conversion, especially with the functioning tailgate and use of squareback rear lights. I hope the legalities can be sorted without too much hassle!
isn't it a fairly recent thing thats been added to the sva test? I'm sure that only a few years ago this type of conversion was perfectly legal. I would check to see if there was a cut off point, i.e. cars modified before a certain date are exempt from the sva.
How long ago was it converted?
Are you sure...Chop Shop built this a couple of years ago and it was road legal.
Some good info can be found Here........................
http://www.the-ace.org.uk/
From what I remember of that episode Jon that car was a proper death trap, they probably just stuck a dodgy mot on it :lol:
Possibly Guy...possibly :lol: :lol:
