Would these rims fit my 6n quite easily?
Borbet T
2 16 x 7.5j with ET 15
2 16 x 9j with ET 30
I have the following done to my car:
Front Camber Bolt's set to -2 Degree Camber
Rear Camber Shims Set to -3 Degree Camber
Front Arch Liner Removed
Rear Arch Liner Removed
Rear Arch's Pulled slighlty and lips folded flat
All depends on tyre size...
currently I'm running golf banded steels 14 x 8j
215646_215685828443655_100000067181964_8
i dont know what offset they are if i did i could work out how there gunna sit etc
Was thinking 185/45 would give a decent enough stretch
Id say yes as long as your tyre choice is spot on and your on coilovers then you can make it look spot on. Can you not try one on?
Dont think they do 185/45/16 tyres =/ try 195/40/16's mate, thats what I'm running on my Borbet A's.
