loose seats
evening all, my seats seem to have come loose and rattle when i go over bumps. can they be tightened and if so were abouts are the bolts located?
its a 6n2 gti
cheers
jamie
  • Views 1.2k
Right,
if youre referring to front seats, there is only one bolt, which is located at the front of the seat, its only small, it just stops you being able to take it out the runner.
however, if you undo this bolt, then take the covers off the rear of the rails, then slide the seat alll the way back to remove it... check the plastic parts on the rails (2 or 4 - cant remember) these act as a kind of bush/spacer...when i first fitted my leathers they rattled like fuck, and i noticed the standard seats had these plastic bits clipped on the runners, but the new ones didnt, swapped them over & happy days
Right,
so theres one bolt under the seat? were abouts am i looking?
like, front middle, slide it forwards, theres a rail in the middle with holes in it, the first hole, or second should have an m6 bolt through it (5mm allen key and 10mm nut iirc) that is basically a stop so you cant put the seat back too far, when removed, you can pull the seat back further and remove it as it slides out the back of the rails, you might wanna put something on your carpet, as youre likely to get grease on it
yeah you got it lol.
great stuff. thanks so much guys. thats my sunday filled
just a quick update. took the seats off and replaced the plastic bushs/runner. nice and quite now. cheers guys
