1W Diesel Engine
I ran this as a diesel in my mk1 golf for a time while i fixed my afh, the pump died so its a non runner but could probably be fixed if you can be bothered to service the pump, its even got new injectors in it.
The better reason to buy it would be to utilise the 79mm stroke crank to build a 1.5 g40.
I'm after 120 for it as is in the pictures or near offer.
If you want to use it as a diesel I've got a headgasket and water pump and timing belt you can have.
Pickup in Ringwood or Bournemouth 8-)
provisionally sold
i have a pump and spares for this if its wanted for use as a diesel!
Did this run a 1.9 aef sdi pump off a 6n ?
dont think so- its a specific part as it runs a different direction.
SOLD
