mk4 polo saloon
A mate is looking at a 1.6 petrol mk4 saloon that's come up cheap but he's looking at buying a caravan some time in the future and isn't sure if the engine will have enough grunt to pull it (it will only be a small caravan). Has anyone on here had any experience with towing any thing with one of these? He's currently got a trailer tent which I would of thought would be a breeze for it but I'm guessing its gonna struggle with a caravan
Are they only 75bhp?
  • Replies 15
  • Views 2.6k
Depends, if its an AKL like my estate then no, its 100bhp. But not very good economy wise if you drive them a bit aggressively!
my saloon AFT is also 100 bhp!
should be no problem I would of thought...
d.
As long as it's heavy enough to tow that caravan, I'm sure the engine will cope. Guessing you know about all that?
I don't know much about the weight regs, is it some thing like what ever your towing has to be a certain amount of the weight of the car or some thing?
I always thought it was that the caravan had to weigh less than the vehicle towing it. Suppose it depends how often your towing. If its okay at towing and your only doing it a couple of times a year it should be okay. If your going away every few weeks then you'd want something a bit more suitable like a cheap Landy.
Yeah that's basically it if he's only got a B license; the car must weigh more than the trailer/caravan. As an addition to that rule, it's advised that the caravan weighs no more than 85% the weight of the car. I'm not sure on how much the caravan he's looking at could weigh, or how much a saloon weighs so that's something to bear in mind..
Also the car itself will have a maximum towing weight, which is what Volkswagen has deemed the specific chassis, engine and transmission mix of that actual car will be able to sufficiently pull (this is sometimes given at different maximum hill gradients). It is illegal to tow anything that exceeds this limit. If the caravan weighs less than this value then you can assume it won't have a problem towing it, as I think there is a large safety factor included in this value.
I looked into it alot myself and found some good info off guys on this forum. If you're mate wants to consider it, this link is very useful - http://www.direct.gov.uk/en/Motoring/Drive...les/DG_10013073
Edited by CWA
My SDI saloon says it weighs 1,500kg roughly empty weight so I`m guessing that the cravan would be allowed to be up to around 1,100kgs or so.
Estate is slightly heavier despite being a petrol engined version.
d.
Ahhh, I just went by whats in mine. Slough isnt that far from me either! Might have seen yours about when I've trundled over that way.
Probably be hard work and drink like a fish whilst towing. How about a passat tdi?
Find out what the towing weight for the car is.
Well, my mk4 saloon was a gutless bag of turd IMO.
And I don't understand how a polo saloon can weigh 1500kg? Do you keep paving slabs in the boot? My tdci mondy weighs 1,364–1,578 kg :|
A polo saloon should be no more than 1100kg tbh.
:ninja:
Yeah I was thinking that is an optimistic weight, my volvo estate was about 1600kg, kerb weight was less than that.
A 6N hatch is about 7-800kg.. I doubt a saloon is double that!
look at the parkers website. if it's the 75bhp version then max braked towing weight is 800kgs, if it's the 100bhp version then max braked towing weight is 1000kgs. Both weigh 1100kgs.
a 6n is more than 700-800kgs, a mk3 is 800-830kgs. 6n is more like 950kgs.
to be honest I'd be looking at Passat TDIs if I was your mate. B5 ones go for peanuts.
