Bigger brakes under 13's
So I bought a set of 13" 4spoke revos, forgetting I had 256mm brakes. Doh! So I'm wondering are there any big/good brakes that fit under 13's. Vw2's aren't really enough for what I want, as I'm hoping for big power and I want peace of mind. Rather have more stopping power than I need than end up in a hedge wishing I had more! I'm talking mk2 polo, or maybe mk1 golf/rocco
  • Replies 26
  • Views 4.6k
Nope... there isn't really any bigger brakes that can fit under 13's. I heard about some but could never actually find any information about them.
What sort of power are you going for and in what car?
i looked into this recently and it is possible to have custom 4 pots made for about £2500 :)
and there is no other possiblities! (i spent some time looking into it)
I'm looking at 1.5 g40 turbo. So I'm estimating circa 200bhp-ish.
How well do the vw11s actually stop?
with some decent quality grooved discs and some good pads I've never had a problem, never had brake fade and i give my car some hammer :)
As above, I overhauled my brake system a few years ago to include. VW11s with standard spec Brembo discs, EBC greenstuff pads, Goodridge braided lines, Passat 16v master cylinder, rear brake rebuild with new shoes and fitting kits and some decent DOT5 fluid, and they haven't let me down yet.
yeah but with 200bhp I'm guessing they might be well over their limit...
the only way it could have been done was by a fella i found on e30zone.net called keri-WMS
he sent me a cutout to test on my 239x20mm rotors under my starmags and the height above the disc was fine, it was just the width of the caliper, spacing the wheel out an inch n half would work, so with a proper 13" motorsport wheel you may get away with it, ill look for the diagram and post the link
and they are sub £500 if i recall correctly
EDIT: here is the cutout diagram (just cut out the caliper and put it on card)
http://www.keri.co.uk/wms/4P025-E30-280mm-T20-rotated.pdf
Edited by dubownerbilco
^ what are they then? Actual calipers? Obviously that's a card template :?
its a cross section of a WMS 2 pot caliper, if the template will fit behind your wheels give keri-wms a pm on e30zone and he can help you from there
Right, I see. So it's a custom caliper. Thanks
Nothing ever exists or works until someone does it.
There wasn't a rear ARB until i fitted one off a Rover, and then a better one off a Skoda, 256mm front disc set-ups were rare as hen's teeth until someone used common Vauxhall ones, etc etc.
All you've gotta do is a little research and development.
I'd have found bigger brakes for 13's for sure (there's a good 10mm extra space out from the centre, depending on wheel type, and that'd be some notable percentage extra leverage). That is, if i didn't think VWII's were enough for me. But i do, at least until my impending OEM wishbone conversion, so..
I appreciate what your saying mikey. But I'm not sure I have the required knowledge, or facilities. Or really know what I'm looking for. I have just made some brake adaptor plates for 256mm golf brakes, but it's taken mr quite a while!
How has the arb improved handling mikey?
tbh it's not that difficult to buy a radial mount 4 pot calliper with some adaptors and get bigger discs under 13" wheels. The problem is wheel choice and offset more than anything, e.g on a mk2 escort you can quite easily fit 285mm disc with a 4 pot under a compomotive ML 13", but you'd never manage it on a polo purely because of the hub/wheel offset.
I think you could quite happily run 256mm discs under a 13" with the right calliper and wheel choice (although that's probably not going to be revolutions)
The only ones I can think of are KAD 6-pots but they'll cost you £££
my mate has 256mm calipers (lucas 54) and he had them fitted to his mk1 golf with some motorsport compomotive 13x9s, they cleared wiwth no issues, but had a silly negative offset!
alsi any kits for mk1 golfs will fit mk1-3 poloes so ask on clubgti as to where you can get the wilwood kits for 239mm rotors
Edited by grungeisdead
Are rotors those weird discs that arent really circles?
Seems like the plans have changed now anyway, and i wont be getting so much power. However, I'd still like bigger brakes under the revo's so keep it coming!
Also I dont mind running negative offset as they need spacing anyhow. But how silly is silly?
its not ET specific, its also down to the internal design of the wheel. I cant remember his specifics, and i dont see him that much! soz
That's cool. When I get round to this, which will be no time soon, I 'll have to measure up and think about it then
Thanks for the help
can fit bigger brakes under 13" Compo CXR's if spacers are used
I must say you are creating plenty of interesting threads sir :)
Have you tryed them? I've got 256's on my rocco and I'm running 8x13 splits and they clear.
If you're on about Chris, his wheels are et20 so not negative, with Compbrake 4 pots and grooved discs 8-) That car sounds like an aeroplane landing when he brakes :lol:
Like Saf also said, Wilwood do a 4 pot kit for use under 13" wheels. If you look in some of the trader catalogues for classic Minis there's loads of options!
Edited by Phataz1
It was Robs old compos he used to have on.bigred :-)
Well I finished the custom adapters and got the 256mm girlings fitted. Test fitted my 13x6 revos too (unsure of offset) and it seems they will clear with about 25mm of spacers. So any one wondering, it is possible.
I didnt actually bolt them on, as the bolt spacing is weird. The spacing seems to be 4 1/4". Any ideas?
