2 pages of advisories!
Just squeezed my polo through the MOT after doing a solid month of work on it. It passed but the bloke reckons I should scrap it in 12 months time.
Advisories were (takes deep breath):
Brakes advisories: RBT front brake imbalance: 24%
Nearside rear (outer) suspension component mounting prescribed area is corroded but not considered excessive.
Nearside rear (inner) suspension component mounting prescribed area is corroded but not considered excessive.
Offside rear (outer) suspension component mounting prescribed area is corroded but not considered excessive.
Offside rear (inner) suspension component mounting prescribed area is corroded but not considered excessive.
Offside front wheel bearing has slight play.
All brake pipes slightly corroded.
Nearside vehicle structure slightly corroded withing 30cm of towbar mounting.
Offside vehicle structure slightly corroded withing 30cm of towbar mounting.
Front brakes only just met the front brake imbalance requirements. I t would appear that the braking system requires adjustment or repair.
Both rear strut tops weak and patched repaired.
Both outer sills patch repaired.
Horn on separate switch.
Long foot brake travel.
All floor pans corroded.
Front pads low.
Front brake disc corroded.
Chassis area where rear beam mounts slightly corroded.
So, looks like I'll be scrapping it next year. Engine has only done 34k miles so if anyone wants it they can take the whole car for whatever the scrap price is when I come to get rid.
  • Replies 23
  • Views 2.5k
ouch!!!
That's nothing, mine failed on this last time:
002 Offside front Brake hose excessively deteriorated [3.6.B.4d]
003 Nearside (FRONT AND REAR) Brake pipe excessively corroded [3.6.B.2c]
004 (BOTH REAR) Brake hose ferrule excessively corroded [2.6.1]
Scared the shit out of me when I saw that.
Edited by MattLoaf
I'll bet, there's nothing worse than finding out your brakes don't work. My mum bought a mondeo off a bloke, I took it up the road, braked, and both rear broke hoses exploded. Brown trouser moment.
I'm gunna fix the brakes and leave the rest of it.
sounds like you need to learn to weld
I think this car needs a priest not a welder
id take all the slightly corroded advisories with a pinch of salt, from looking at the other advisories he's listed. Id have a look myself first, but that advisory list just screens mot tester is a nob to me.
My favourite advisory iv had:
Vehicle lowered to excess, could be considered dangerous. check suspension components periodically. **DANGEROUS**
I checked the floor pans before the MOT, there was surface rust on them, a quick wire brush and some underseal and it'll be fine. If the rest of the corrosion is the same then it'll be ok.
TBH I'd rather just get a new car anyway, I've been wanting a caddy for a long time so this seems like a good excuse to get one.
I've had worse, nothing a few pints with the tester can't fix! get the work done for mates rates.
Seen worse... The car in question got 2 pages of fail. Got that fixed, went back and got two more of the stuff the tester couldn't be arsed to write out the first time because he didn't think anyone'd have the dedication to fix the first fail sheet :oops:
Just replaced the brakes, didn't realise how bad the old ones were til I fitted new ones. There was about 3mm of pad on the drivers side and 2mm on the passenger.
The new pads are that much thicker that the master cylinder threw a load of brake fluid out the top.
Just gotta remember the brakes are good now so I don't put my face through the windscreen everytime I stop.
I do this every single time I move someone else's car, the amount of travel on my Mk2 pedal before you really feel the brakes kick in is enough to basically do an emergency stop in a modern car. Same with the steering and the boot; I end up hurling the wheel around and absolutely smashing the boot closed on modern cars.
My favourite advisory I've had was:
"Semi-prepared track car"
How is THAT an advisory?! I'm sorry, should it have been FULLY prepared?! :badgrin:
Just had mine done and two i got from it were:
Subframe damage due to grounding out
and then
Wear on chasiss due to driveshafts
Remove the tow bar unless you need it. That's 2 down ;)
Towbar is only there in case someone decides to borrow my brakes. And as a parking aid :p
I had to remove one of the braces to fit the exhaust so I'm suprised the MOT man passed it at all.
Edited by hammerong
:lol:
also:
obviously your tester has never driven an early polo, they're all like that :lol:
I have mine on Monday and before that I need to strip out the back seat (no seatbelts fitted) and if it does pass it will have a few advisories. Normally i have time to work on the car before the MOT but with my job I've not had a chance so the chance of a 1st time pass are pretty slim :( but once its been in i will have a list to work to, so fix what required and drag it through.
haha, obviously not race-spec enough for them :badgrin:
As for the original list, it's not that bad really. Most of the corrosion things probably just need sanding down, treating with anti-rust stuff and painting. If it was at the point where it needed welding then they'd have failed it I'd have thought.
Then you need to fully rebuild the braking system by the sounds of it. Brake lines, discs, pads, fluid, rebuild rear drums and replace any thing needed. Assuming the rear drums just need a clean up and adjust, this stuff will cost you less than £100 in parts, much less actually. Brake pipe is cheap and not that hard to do really as long as you can borrow a decent flaring tool.
It's when you have to argue for the guy to have your keys back. then not being allowed to drive it, having the biggest guy who work there watch me make sure its towed out of the garage with the threat of the police being rang if I tried to drive it. ahhhh this has been a long year of 'servicing'.
pah! my brake lines split while being tested. sure to say there is a fair amount of new parts on mine now...
i enjoyed my last mot on my old polo -
exsessive fire damage too engine bay electrics
strong smell of fire in cabin
exsessive fire damage too n/s wing and light
exsessive fire damage too master cylinder
and then about 10 different places of rust
Spent £40 on parts so far, new shoes on the rear, new pads and discs on the front. Brakes are spot on now, I'll get round to the pipes when I get round to them.
Like you say, if it was that bad it'd be failed not advised.
I'll probably sell rather than scrap, someone will have more time for it than me. Just a shame I've spent so much money on it, new springs all round, polybushed front end, new exhaust, new tyres etc etc.
Edited by hammerong
1 page, 4 fail items, 1 advisory
Left TCA ball joint excessive play
Right Ball Joint excessive play
Hole/seam split in passengers sill
Emmisions - CO level excessive
Advisory: Heavy Corrosion on sill seam - re-welding recommended
Not all that bad, booked in for welding at 9am, ordered the TCA's, just need to get the stem seals to sort out the emissions issue caused be oil burning (tester didn't believe it was the rings and said the stem seals were more common)
