wobbly bolts
i have 16 wobbly bolts for sale, will fit a mk1 and mk2 polo, not to sure about mk3 should do, if not then i have another set which will fit mk2 onwards.
Corrective bolts are normally used to fit wheels designed for common fitments (such as 4×100 PCD) to cars with rarer fitments (4×98 PCD). The 2mm of movement that the shim provides is just enough to allow the bolt to locate securely into the bolt hole before the threads tighten it up securely.
£40 including p&p
07887403093
  • Views 484
25 delivered brand new ;)
if thats right then
20 deliverd
