mk2f lightwegiht body panels
just thinking about some lightweight body panels for my mk2f and was woundering where i could get some, i dunno if they are already made or if it would be a one-of-kind of thing, I'm not bothered if they are carbon fibre or fibre glass. does any one have any idea where, I'm intrested in boot, bonnet but more panels i can find the better. sorry if they is wrong section but wasnt sure if i should put it in the bodywork section or not
just to add if i cant buy them does anyone know how to make or has already made some in the past and can give me some tips and advice please
Edited by pascoe92
  • Replies 9
  • Views 1.7k
they become light on their own as they rust lol
might be worth asking ppp see if they do anything but you may pay through the nose
Hi buddy I did this type of thing for a liven for 8 years and belive me I say this no disrespect or any thing but you wont be able to do it your self it takes a certain person for this type of work it is extremely difficult and takes a lot (SKILL) that can't be learned of YouTube or read of the Internet it takes grist hand experience and a lot of it
There is ( A LOT ) that can and will go worrg especially when you don't know what your doing
Secondly it's very costly to start produceing fibre glass and carbon / carbon kevlir products & it's very costly to can't a mould made it's any were form £800 to £1000 and in some cases much more
In most cases no one will made a mould unless it can make money for reasons such ad the is a (A LOT) of time in making mould (A LOT) of materials in making moulds and (A LOT) of cost in making moulds
Here's a quick run through of the process of making a mould
First you need a (prefect) panel to use as you base for example say it was a bonnet it would need to be (PREFECT) no dents no ruins no orange peel no hard edges you pant needs to be 100% prefect because every bonnet that comes out of mould will be the same so the need to be prefect
Then once you have your prefect bade panel you to buff it with a buffer to a until you have a super shinny surface
The you need to wax it with mould relise wax it need to be done seven times and then every time you use the mould half that (this is what makes the new bonnet come out of the mould so it needs to be done right)
Edited by doyler
When there is any akwardshapes you need to put flanges in the mould this makes the mould easier to separate usally made use card borad
Then you gel coat the mould this is like a think White paint but (obviously it's not white)
Then you have to skin coat the mould use real thin fibre glass this help prevent air bubbles then you rub the skin coat down to get rid of any hairy sticky outy bits that will cause air bubbles
Then you would lay down the fibre glass usen resin for making moulds there are differnt wiaves of fibre glass 300 450 is the common ones for bonnets bumpers etc you would use a variation of the above to make your mould
Once the fibre glass Hardings you will need to finish you flanges to complete the mould
Once all of the above to done you will need to trim all excess fibre glass form the mould and the drill holes for bolts for the flanges the remove the plug (for example the bonnet) then sand all of the edeges of the mould then wax it seven times and before each time you use it gel coat it then lay down your fibre glass then that basicly it
Hope this helps buddy and turst me I know what am talking bout ! ! !
Stuff fibreglass, just use vacuum plastic. Moulding company places panel in machine, lays poly sheet over it, switches on, you trim resulting mess in all the right places and pull original panel out from it, now you have a panel made from a sheet of thin stiff plastic instead of steel (like the front wings of Renaults etc, though they use a different process) in one hand, and the steel one in the other.
Belive me buddy sounds easy and simple which it is but its the costs there are stuiply insane for plastic moulding 3 times as much as fibre glass
We (PPP) don't sell any GRP panels any more, the ones we were importing were cheap - but the supplier was very unreliable in terms of quality and timing.
I've been eyeing these up, which look fairly decent in the pics:
German eBay
German eBay
Hi Andy glad you posted, i have been wondering about the diffuser that is on yoof car and where you got it or if you made it could you make another ? Pm me
And them doors do look good if you are planning on getting a set I'd like to know what you think of them and what the quality is like on them,
My plan for the lighter panels it I just want to loose as much weight from the car as possible and lower its centre of gravity.
Doyler - cheers for the advice but I've seen a process of doing it that I think will be ideal and I'm one of them people that can turn there hand well to practical things and I'm abit of a perfectionist, what I was planning on doing is using my panels are the male part of the mold to make the female part of the model and then I should be able to use that to create the new panel, then do the same with the otherside to make the complete panel, I will put pictures and writing up of how I do it step by step and I plan on making the mold I use to be used a few times so if anyone wants a bonnet or boot or even wings and mine turn out well I would be happy to make more panels for a fair price.
We can get another diffuser made up - it's metal and needs the spare wheel well cutting out to fit. We can supply the diffuser and a spare wheel well blanking panel, email: enquiries@poloperformanceparts.co.uk.
Cheers, I will write you email down.and get back to you near the time I will need it
