1.0 to g40 brake conversion
could sum1 please tell me a complete list of everything i need to carry out this conversion
list of parts please
  • Replies 15
  • Views 1.6k
VWII Calipers, Vented Discs and pads to suit.
Job done.
Job done.
How can you tell if there VWII
They have VWII stamped on instead of VWI :)
If you're as tight as fuck, you don't actually need the brake pads, because VWII pads are the same as VWI pads, but a tiny bit thinner, like if you've used then a couple of times. :lol:
What discs? and do you need green stuff pads?
you can go into any motorstore and ask for a set of g40 disks and pads just not halfords as they charge far far to much I'm fair sure you could use the pads already on your car but for even wear id stick to the new ones. if you want green stuff pads ask for em they do them and also drilled and grooved disks and braided brake hoses if you have the money spare
braided lines
green stuff pads
grooved and pimpled disks
Edited by m4ttyf
One of the two bolts that hold the caliper on is also longer on the g40's
id forgot that cheers guy btw did you ever find that spare one you had
You may also need carriers if you have the early type (though I'm guessing you don't if they are going in your mk2f coupe)
There like 50p from VW.... :lol:
60p inc VAT :ninja:
no you muppets not the bolts the caliper my blead nipple snapped
Bleed nipples are a couple of quid from VW ;)
Can get you part numbers if you need? They come with sexy little rubber hats too ;) haha
i cant get it out of the caliper its stuck in there well
Totally forgot about that Matt, I think I saw it in the boot of the jettee the other day, I have a check later
Same, I'm getting one drilled out of a set of VW11's i just bought.
