revolutions 4 spokes
Yeah, I'm spaced 35mm at the back and 20mm up front
  • Replies 32
  • Views 3.2k
well I've used them on mine before and had no probs
i'll get some then as you have a g40 and i trust your knowledge :thumbsup:
tis probably because they are listed for golf fitment. what calipers are on your car?
standard vw1 ones
might be worthwhile emailing or phoning them to ask why they are listed as for rear drums only. i cant see them being an issue though
turns out they don't fit 100% front or back on the polo, the centre bore ring thing on the car doesn't go far enough into the spacer so the spacer is about 4-5mm from resting nicely, so there is a gap between the spacer and the car so i'm going to have the spacers machined down 5mm so they sit correctly, hopefully this should sort it! for the front anyway :retard:
hmmmm, not sure i get what they mean. On my ones they fitted the front hubs perfectly, although when i tried them on the back the centerbore on the spacer was too tight, so the spacer wouldnt sit flush to the brake drum. guess you will find out when they turn up. I cant for the life of me remember what make mine were. I bought them from the same place though. I will go and search my photobucket account to see if i can find a pic of them.
found the pic, was hoping the box would be in the pic too, but sadly it isnt
i have got them thats how i knew they didn't fit right, i had tried them on! the centre bore ring on the hub hits the edge of the spacers centre bore ring cut-out too early and the spacer itself then doesn't touch the hub, basically the ring cut-out needs to be machined down so that it is then allowed to sit flush with the hub, ands they look the same as those you posted
Edited by VW+SWFC=:)
