Mk3 recaros
Speak to me about the above !
  • Views 773
Front fit straight in, literally undo one bolt, slide off backwards. Rears need polo backs putting onto them but very easy. There are quite a few threads about it. Google it
fronts straight fit same bolt in the front of the golf seats as the polos have just remove the plastic trim near the runners (on your polo).
rear bases you have to remove a bracket from the bases so they can slot into the holes provided in the polos
the rear backing of the mk3 golf seats will be to wide its not much but its to much for a polo so you have to remove all the material from the rear metal and unscrew the headrest from inside the seat
do the same for the polo seats and put the mk3 golf material and foam onto the polo backing plate and screw the headrest back in.
watch your fingers on the backing plates as they are pritty sharp.
