Always replacing wheel bearing?
I seem to be always replacing wheels bearing on my mk4,
why is this??
are you using known brand /genuine ones ...or ebay /ecp cheapies
I've found cheapo ones dont last 5 minutes , try and get genuine /FAG/SKF if you can
Cheers for the info m8, I use CES! But there's a place called trades an part which u probs no of I use them mainly which there stuff is bang on, i think I should go there in stead!!
Edited by Dubbrad
Unless of course your rear bearings are like mine on the 6n2. Its a sealed bearing and to replace the rears ou have to buy brand new hubs!!! £135 from vw :shock:
So ebay it was, bought it for £35 and its holding up nicely!!
front or rear? as above you may not be fitting them properly, or your rear stub axle or front hub assmebly/front stub axle might be fooked.
