twin jet washers mk2
Hi,
I know this has been done/there was a thread on it but I can't find it!
anyone know which twin jet washers fit into the standard mk2 bonnet holes??? this single jets are a bit pissy and usually takes at least 3 sprays to get proper coverage.
Thanks.
Edited by Narrow_Lane
  • Replies 17
  • Views 1.4k
my 88 has twin ones as standard...
if ud have got a leter one, you wouldnt have this problem like myself ;) 1990 ftw!
Iffoundfacedowns's 89 has twin ones too.
There the same fitting as all VW's in the mk2/3 polo era, you can also fit the heated items and wire them in :)
It's an early/late thing, so 84/5 changeover.
Not true.
Depends which bonnet you have.
The earlier holes won't take the later jets, i have heated ones from a MK2 Golf and twin jets from my old '88 but neither will fit my early bonnet.
Bit of dentistry will sort it, combined with some sealant to prevent rust.
Mikeys.correct cymro! You read the.disclaimer at the top :-p
I swapped bonnet on an 84 the other day and didnt notice a difference in hole shape, unless the bonnet had already been swapped in the past but I'm sure they were only single jet.
the early bonnets have the same openings as the mk1 olop bonnets. my yellow one was build in january of 85 and has the early bonnet and washer jets.
i replaced the bonnet when i first bumped the car with a later bonnet and found the original washer jets didnt fit the new bonnet! PITA. now back with an early bonnet on.
mk1 polos only has one bonnet jet, and I'm pretty sure they are dual jet, ill check tomorrow when i venture out the house, pretty sure that I fitted the mk1 jet to my early mk2 bonnet, when i lost one of them...
either way the jets are pish in comparison to my mk3!
I wasn't bothered by the singles before, but now i have a 4L washer bottle i'll certainly be using heated twins this winter.
the mk1 polo does has a single twin jet washer. i have one fitted on the driver side of the peril, as i snapped the original single jet washer when i was changing the bonnet
right ok, so basically either have to cut a hole for the later jets or find some that fit in the existing hole. what about the golf/passats of that era? looking for other cars I can cannibalise off!
I can't be arsed changing bonnet just for the jets as I would have to spray it too... and Mikey are you going to cut a bigger hole for the heated jets? and where are they wired to? ignition switched? I have a 4L bottle as well just filled it up, good for the whole winter I expect :)
Fit a later bonnet with twin jets already in them? (Long shot I know)
read the post above yours bro
*Facepalm*
*Facepalm*
ahahaha :lol:
yea....l2read :retard: pfff
finding a russian bride to lean out of the window with a sponge is easier than finding a beige early mk2 bonnet...
I'll get the measuring tape out and find out the size of the hole 2moro (oo er)
Four litres will probably last me three days with the mileage i'll be doing on the salty roads this winter.
Yeah, it'll be a five minute job fitting the jets in the bonnet, i'll run oem with them via the rear heated window switch (so they're on with the window).
