6n2 dash in 6n
As title states I'm looking and just gathering info on how easy or hard it would be to put in a 6n2 dash in a 6n polo. if anyone could give me feedback on this and if anyone has done this in the past.
i understand all wiring looms will need to be changed aswell.
thanks
ollie
  • Views 881
thanks
ollie
If you do the engine conversion then this is straight swap.
if you want to keep your engine the you need to prepare to spend a lot of time with cable wiring.
Too much hassle without engine conversion.
I done mine the 'Bodge' way by spicing the looms and it works apart from revs, airbag light and handbrake light but i wasnt happy.
I'm now in the middle of an engine conversion anyway so have decided to fit the whole new interior loom so everything should work.
I would recommend replacing the whole interior loom and then you will need to make up some brackets to hold the dash since its slightly different on back of bulkhead (around 5mm out) and the side brackets are completely different so you will need to adapt this to fit the new dash.
harry
cheers guys, had considered doing engine conversion and interior aswell just wanted an insight on how hard it would be and whether it is worth it.
