custom pickup on ebay....
OOOOOOOH HAI!
just found this gem, and think it could make someone really happy, so thought i'd share it with everyone..
CLICKY
if its a repost, i will kill myself
  • Replies 9
It is a repost - but its not been forsale in a while :lol: 2k is pretty cheap though compared to how much it was last time
I wondered where this was hiding...i love that...but not for two grand
i was alot more last time it was 15k maybe i might be wrong
I'd rather set my eyes on fire than ever see that car again.
id rather look at it but i see what you mean, it is one fugly creation.
"may need an sva"
Well that clears up a comment made in the last thread about a polo pick up, some one mentioned about this car and said that it must of passed an sva test so it must be possible to make a car based pick up road legal... Looks like Bernie and leepoo were driving it illegally :lol:
Hasn't that supposed death trap been crushed yet?
I'd be interested to know of anyone viewing this, to confirm the programme correctly showed them complete the vehicle with one of the trailing axles the wrong way around..
I know they only pretend to be retards for the entertainment, but i'm sure that's how they made it appear they sent it out.
Maybe only the inner axle is braked, and the outer one simply has idle drums, i dunno. And surely it's been tested and re-registered properly because they used it on the road.
Dunno why, when it's clearly made for water..
If it had been properly tested I doubt he would say it may need an sva "to cover his back" as the seller so eloquently put it. Not sure about if it was the case when this was built for I'd imagine it was, there is no test for this sort of conversion but you would need it tresting before it can be used on the road. Here starts a never ending game of pin the tail on the donkey involving you and vosa, they say you need a test, you try and book a test, they tell you there is no test for it. They then tend to remove you registration until the car is tested even tho they know there isn't a category in the test for this sort of car.
It's a very confusing, long winded waste of time but what more would you expect from a government body? :lol:
Also he says it must of cost at least 10k, where? It was literally chucked together in a shed using standard parts and slave labour
Well if there is a test and it has brakes on the outer axle it hasn't a hope in hell's chance of passing - only the slightest tap of the brake pedal and the middle axle would lock up as the back pivots up into the air, lifting the middle axle, and pulling all the rear shocks/springs open.
If the outer axle is unbraked and they've uprated the other brakes to suit, that still doesn't make it bulletproof - the second axle will lift the back on a speed ramp and leave the third axle pivoted side-on into the ground, so it may not compress, acting instead as a barb.
Seeing the thing tear in half whilst negotiating a speed ramp would at least be entertaining.
If there isn't a test then having 'two axle rigid body' on a logbook for a three axle rigid bodied vehicle absolutely kills it legally, no insurance would be valid on that.
Only really any good, it seems, as one very ugly ornament.
