Jacking Points
I know it is boring but I think this would make a good sticky.
We should list all the jacking points for different models so people with "lesser" mechanical knowledge know what they are doing before they jack up the car.
Not only would this be a good idea from a safety point of view, but it would stop alot of holes in floors and bent sills etc.!!
  • Views 3.5k
And print the list on posters. And deliver said posters to all the tyre fitters in the area.
Or you could just go by the arrows on the sill..
Well I would hope that everybody knows about the arrows on the sill, what I'm talkin about us the other areas to jack a car up, like say you were doing work to the sill of the car or you were doing work to the wishbone mounting points where are the other areas to jack up the car?
I've seen too many cars slip of axle stands and jacks, , see and think it is important for people to know where the best places to jack a car up are.
For the Mk1 - Mk3, jacking them up by the sills seems a bit risky to me, as the sills are quite delicate at the best of times and are easily damaged by a widow maker jack. It's far kinder to jack them up at the front either by the inner end of the TCA (trolley jack only) or the big plate welded to the front of the floorpan, about 4" in from the front of the sills.
For the back, I tend to jack mine up by the rear beam attachment brackets - again using a trolley jack and a bit of wood.
If you have a stage 3 subframe then the front bar of the frame makes life so much easier, especially as I've had to get my sills rewelded due to past jack damage
Good post! Very helpful.
Agree with everything above.
For a trolley jack, it's a matter of preference, but I normally jack the rear of the car on the crossmember of the rear beam as it's nice and flat, and has some handy boltheads sticking through to stop the jack slipping. I can see why saloon owners wouldn't though. I also find the front antirollbar bush mountings to be fine to jack by, and less chance of slipping than the TCA's if you're using a jack with a large saddle.
I jack up the front with the arb mounts, then get it on a stand, then jack up a bit higher by jacking on the tca mount. my mk2 is down 80mm so have to be creative! wouldn't ever use a trolley jack on the sill.
