What is that foaming car shampoo called?
I want to give my car a proper proper clean, I was wondering what that foaming shampoo was called, where it completley covers your car in white for about 5 minutes..
Anyone know
Where can i get it from and how much etc?
  • Replies 9
  • Views 1.3k
it's called snow foam, don't know about prices though sorry.
Doesnt it have to be applied by gun?? I'm almost sure it does. But you cen get it off ebay, your local motor factors may sell it or bodyshop supplies, but best bet would be on the net somewhere
And just to reinforce what the gent said above, it is indeed called snow foam.
you need pressure washer, snow foam gun and snow foam shampoo.
The gun is minimum 40quid+25quid for 5L of shampoo.
The best is contact Autobride, they have the best deal out there now and the best snow foam.
I have purchased one couple of weeks ago and is awesome!
The foam stays on the car for 15 minutes and then you just wash it and dry it.
This is perfect for quick detailing and I'm happy I have spent this money on it.
Cant it also be damaging to the paint, I mean, it might remove lots of grime etc as its sat on the paint, effectively doing the work for you?
I wouldnt be keen using it on a regular basis, I think any chemicals that get dirt off easily are also going to be harming other things, or stripping your wax's/polishes/sealants in the process.
Its good to start a detail with mind,
Jet wash
Snow Foam
Wash using 2/3 buckets (one with soap solution) one to rinse the dirty sponge so your not putting grit into your clean bucket.
Dry
Mop with compounds to correct the paint swirls/scratches/marring
Seal
Wax.
After that you should literally just be able to spray grit off with a hose and wash with wash and wax and a microfibre mit and dry, maybe an application of detailing spray and it will look sweet for a while, its just the slow introduction of swirls from washing, however this depends on your method.
Karcher do a ''snow foam'' lance for about £15 but its not adjustable or anything, its just a pot you put the chemical in and it will spray foam still, I have one which I adjust the flow with the pressure adjustment on my pressure wash, but I dont use snow foam as I dont see the need.
Obviously snowfoam isnt a bad thing, as lots of people use and reccommend it, I'm just not entirely convinced it will be too good on your paint for frequent usages.
Read up on detailing world and other sites, people frequently discuss the mixture ratios etc :)
Nick
I'm going to get some snow foam but need a pressure washer and a lance so i have been looking aroun and seen this:
http://www.argos.co.uk/static/Product/partNumber/7420205.htm
It has really good reviews from people who of owned Karcher ones etc and i don't want to spend £150+ on something i will only use periodicly. Oh and this one comes with a lance for using Snow foam it can be seen at the end of the video:
http://www.argos.co.uk/webapp/wcs/stores/s...ssure%20washers.
thats just your bog standard shampoo foamer, I had one with my Karcher and it was shit compared to the proper foam lance.
the mix was too watery and the foam just washed off with the proper lance the foam was almost like glue.
Snow foam doesn't strip waxes of other finishes off either.
ah right. bit of a shame that is :( can't justify spending money on a lance at the minute so looks like i will leave it then.
Xmas is coming :lol:
just about to order my winter stuff, last year I used snow foam just to get the salt off every week.
Its funny when the foam freezes too.
Jet wash
Snow Foam
Dry
Seal
Wax.
Nick
If you are going to be using Snow Foam for a detail a high mix can be used as said above, but for more frequent use you can dilute it down and it will have no detrimental affect on your protection aslong as you are using a good washing process (not using too much shampoo in your bucket) stripping your protection with snow foam would take a very very strong mixture. I use 1:15 ish sometimes more and i have never had any issues with protection not lasting the desired amount of time,
