Stress cracks.
Basically have just found a crack on the passenger side turret under the washer bottle.
Have drilled the end of it and attempted to weld it up. should this do the job or am I just delaying the inevitable?
Will be devasted if i have to scrap the old girl :(
  • Views 1k
pics!
Gives you an excuse to seam weld your car :D
get some pics up so we can see how bad it is,may get some good advice :thumbsup:
I've heard of the same problem a long time ago on a Mk1, is your suspension particularly hard? If its welded up well then that should be that, but I'd be tempted to keep your eye on it just in case it starts again. I guess worse case scenario, you could graft in a piece from a good mk2/3 for a more permanent (but expensive) fix.
i didnt have my phone on me so didnt get any good pics of it, now its just a welded line. however you could see daylight through it.
Vic, when you say graft in a bit, could i get new ones or would it have to be from a donor car?
I'm fairly sure you'll struggle finding a new piece, unless you could track down a new inner wing from VW, but that's going to be expensive. It's a fairly rare problem, so I would imagine that you could chop the relevant section from a scrap car then graft it in for a long term fix.
