Polo 9n3 Speaker Size
Was looking to find out what is the speaker size for both front and rear doors on a 5 door 9n3 Polo match, as I would like to upgrade the speakers in my mothers car :-)
Also what kind of speakers would you reccommend, and would the current headunit be able to pump enough power into them.
Joel
  • Views 12.1k
Popular Days
Joel
Do you have speakers in your rear door? Either way your better off with a set of components. Mid-woofers are 6.5"
This means replacing the two mid-woofers in your door and the two tweeters in the column above your dash next to the windscreen.
Can't go wrong with a decent set of Hertz.
Hertz @ Car Audio Direct
Video on TouTube
the base stuttering is just his rubbish camera.
You'll probably find (like most) people that the standard speakers are good enough. Installing a small Amplifier + Subwoofer to take all the bass away from the original components improves the clarity of the sound dramatically.
Edited by nick0323
