Mk1/2/3 stainless exhaust manifold
Bought a stainless manifold off eBay a while back and have never got round to fitting it. I have now decided I'm gonna leave it standard exhaust wise!
I had a lambda bosspeofessionally tig welded into the Decat section in the same position it would be in on a standard mk3 downpipe making it perfect for a ml3 but could probably have it blocked over if you wanted to fit it to something earlier.
Looking for £160 due to the extra cost of the lambda boss being welded in.
As said this has never been fitted so has no build up of crap inside it or anything.
can upload more pictures later on if there is any interest!
http://s1114.photobucket.com/albums/k534/i...nt=IMG_1105.jpg
Edited by adamburton93
  • Replies 14
  • Views 374
very interested mate, you say you got some pics, will it fit alright on the aav?
yeahh should fit straight on, however i haven't actually fitted myself so don't know for sure, but i don't see why it wouldn't fit!
You may have clearance issues with the arb. Cured by a set of arb blocks from ppp or g-laderseite.de.
Forgot to mention that, cheers buddy! Mk1-golf-chriz used some spacers on the standard arb mounts temporarily to clear his manifold if you didn't wanna splash out on a set of blocks though!
Yeh that's what I forgot to say, bit concerned about that, but some of them fit ok so hopefully will be alright, fdo you know what make it is?
Should fit the AAV fine. With regards them hitting the arb if they do its always very minor just something to consider. As said arb blocks or similar sort it out if it does become an issue (and they are an excellent addition anyway). These manifolds are more of an issue if trying to make one fit onto a G40 as they foul on the charger.
Ok sounds good, will super pro arb blocks to the job? I take it its possivble to modify the downpipe if possible!
Haven't seen the super pro ones, but as long as the pull the bar forwards, you'll be fine. Yeahh you can bend the mani a bit to suit if needed, seen a few people do this!
As far as make it concerned, I'm not 100% sure, all I know is it came from Germany!
Right ok mate, its the same as the one phil jackson used to sell or still does, so i would imagine it should be ok!
How much would you post it for, as am a fair trek away to pick up unless you'd be willing to meet half way for me to take it off your hands?
Replied via pm
not recieved your pm dude?
Didn't press send, fool.
Will send you it again in a bit :lol:
haha, no worries mate :L
sold!
