Stock power from Mk2 Polo
What is the output from the stock 1.0 and 1.3 Mk 2 Polos? Cant find anything on 'tinternet other than G40 figures. Had a search here and no luck (watch someone find it and show me up!)
Thanks guys
  • Replies 16
  • Views 1.3k
If you've got a Mk2 instruction manual they are all in there. I think the 1.0 is around 40Bhp and the 1.3 is around 55Bhp.
Edited by MattLoaf
when new remember :smirk: but that sounds about right
Thank you guys, I am without Polo right now but the shakes have started so I am looking for a new one. I'm used to PoloPetes 100Hp ABD loony machine, I wonder how many ponies will have escaped, and how many I can get back.
Haha yeah, once upon a time.
Edited by MattLoaf
39/55 so long as the carb's healthy, the ponies tend to stay in the stable
i heard the older solid lifter 1.3s were a bit more powerful than hydro? that the solid is 55/hydro 50 ish? is this actually true?
Nah that's false.
According to VW:
GF/HH (very early Polo 1.3) = 60hp
HK (82-84 Mech head) = 55hp
MH/2G (84> hydro head) = 55hp
In my opinion and experience, if anything's wrong, it's that the outputs for the HK are conservative, seat of the pants estimate says by about 10hp.
Nah that's false.
awesomeeeee
According to VW:
Iirc, doesn't the hh use a weber 34ich weber? Might explain the slightly higher output.
I'm not sure to be honest, I'd have thought a single-choked solex/pierburg like on the GF.
A few years back we picked up Saf's yellow coupe S in it's original HK form. The support car for it's run home was my MH'd Coupe S. I'd spent a lot of time setting mine up just right, Saf's had had some petrol chucked down the carb and a jump start. Sufficed to say, on the run home, the MH got left for dead by the HK :lol:
so true, when I had a pooberg it was sluggish, the pooberg imploded on itself and rather than rebuild it I put on a weber 32/34 DMTL and it was miles better.
Thats good to know, ok looks like the 1.3 is the one to look for
Between 40 (early 1.0) and 60 (early 1.3) The mech head engines are a bit quicker to rev but require more maintenance. The early ones use solex carbs the later ones use pierburg. Some late 1.05s use a single weber. Etka rates the 1.05 HZ engine as having 50hp although all official literature says otherwise.
1043 hz mk2s with the pierburg had 45 stock :)
Yup, that's what engine is in mine. Supposedly its 45bhp although it feel worse than that lol
