will the coilovers from a 6n fit a 6n2
will the coilovers from a 6n fit a 6n2?
  • Replies 10
  • Views 7.4k
Nope mate Someone will correct me if I'm wrong but I think the fronts will but the rears are different so won't fit, either way I know they definatly won't fit!!
it was few times on forum
rear - will fit
front - will not fit as 6n2 got bigger diameter springs, but you can use coilovers from 6N with springs from 6n2 coiles
rear - will fit
Thats correct, the front springs are different due to the front top mount on 6n and 6n2s being different.
Pete.
Thanks people massive help... just means ill have to save up for some 6n2 coils now :(
6n and 6n2 coilies are the same price!
Thought I replied to this thread already!!! Why was my comment deleted? There was nothing wrong with what I said!!!
Edited by Monkey-man
Chill Man of Monkeys, just checked and theres nothing in the Rubbish Bin from you.
Odd why it didnt show. I've had it happen a few times recently :paranoid:
I thought the top mount fitments were different for 6n2 to 6n? If u look at a set from each the 6n2 has a smaller shock with a fater spring???
Shock is the same, spring is different.
If you look someone has correct the first reply in the replies below.
I Didnt say they wernt the same price monkey-man :S i said I'm gonna have to save up for some.. i already have a set of 6n coils thats all...
but thanks for the advice everyone
Ah my bade, thought you were trying to insinuate that there more expensive :p
But you could get a spring hat milled by your local engineering place. It would be cheaper than buying a whole new set of coilovers!
