fix it or bin it ? HELP
right my gear box has a noisy dif bearing but i dno if i should fix it by putting in a new box or get rid and the engine has about 120000 miles on the clock so is it worth it ? or just a new engine ? what do you all think
  • Views 776
Is this a 6n? well if you decide you want another engine let me know, i have a 6n 1.6 8v engine, with box and new cluth fitted around 100miles ago and new gear box oil for sale :)
as long as the engine is ok it'll go on for much longer. 120k isn't much.
Tbh it's not normally the engines & boxes that go on the 6ns it's the body work that goes first !
Up to u mate, if you are happy with the car other than the gearbox then replace it.
6n boxes are weak so be careful buying a second hand one
